im putting a 6" lift on my truck this month. I have all Tuff Country parts but dont care for the 6" spacer setup. Here is what im lookin at running, a 4" Superlift coil and a 2.5" spacer. My question is about the 4" Superlift spring. How does it sit? Does is sit at a 4" lift or does it sit a bit lower than 4"? How does it hold up over time?
I used the skyjacker 2.5 inch springs for my truck as a levling kit and they came about 2 5/8 so it is slightly over in the front than the rear but I have had awsome luck with skyjacker.... my 2 cents James
Well, i hope so cause i just ordered it... And my JKS Quicker Disconnects for the sway bars. Im gonna order my 2.5" spacer tonight as well.... Then im down to getting the price i want on the 22" KMC Monsters and Toyo 37 M/T's.....
Why not just go with 6" springs and not worry about mixing springs with the spacer?
Most 6" kits i have looked at are not a true level. I want to try and get a true level stance and not a 1/2" to 1" rakePlus if i run a higher offset wheel the extra 1/2" will help on clearance.
i would go with a 6 inch superlift spring i have put those kits on over 5 trucks and they all sit level if not a little higher in the front
I am still waiting for my 4 inch kit. Guy from Top Gun Customz said that Superlift is "out of coil springs". As soon as they get them from whoever makes them it will be sent out.
For those who have a 6" Superlift suspension, can you post pictures. I am undecided to go with a 4" or a 6" lift. I am going to install a 20x9 extreme alloy rim with Tierra Grapplers 325/60r20 tires.
Tazz
