I finally got down to the dyno after installing my super B and valair dd this winter. Previously I hit 320/680 on stock turbo with 150 sticks with the edge off. With the super b and clutch added, it bumped that up to 354/717. Before with the edge on and 150 sticks on stock turbo I hit 387/816 and after turbo/clutch I hit 422/802. Max temp was 1350-1400 and boost was 43-45. I made several runs while playing with the edge from 5x1-5x5 and every level made almost identical power (varied + or - 4 on hp/tq). I don't think the turbo can handle the fuel on the higher fueling levels. I know that my wire tap is good because on 5x1 we didn't have to clear out the shop after the run but on 5x5 with 2 huge exhaust fans running we still had to vacate the shop for 5mins. I'm happy that I gained 35hp, but dissapointed that I lost 20tq. I'm assuming that it's because the super b has a larger exhaust housing and allows more flow out the exhaust with less restriction than stock which helps hp but shouldn't that help tq as well? I'm happy with my results using this turbo, but think that I need something a little larger (R700 Twins:drool2:followed by monster pump:shock
to burn the extra fuel. If someone could give me some insight on my torque # drop it would be appreciated.
