1 - 12 of 12 Posts
i have 2 10" visonik subs and a 600watt visonik amp and a 2 months ago my spare tire (87 grand marquis) pressed up against one of my rca plugs and broke it off in the amp. So i took the amp apart and pushed the broken peice out and wired in another rca cable end. and they were working fine until 2 weeks ago they stopped working, so i fiddled with the connections and they worked so i tried to make the connection better, and no work:banghead:. new rca cable, subs still don't work, amp is getting power, and everything is hooked up, but I can't find the problem. any idea's? Thanks
Discussion Starter · #2 ·
bump... could an amp show its getting power but its bad?
Amp can power up but have problems in the signal path. needs to be junked or sent off to be repaired. Being that it is visonik its probably garbage. Let me know if you need help picking out a new amp
ill help too. if your throwing it away, ill pay shipping.
what are some good amps that wont hurt my wallet?
Thanks
I bought this one and like it, its a lil steep on price, but looks real nice and sounds even nicer depending on subs. I have 2 12" kickers
TRX1500D
probably around the same as the visonik, 600 watts to power the 2 10" subs
The amp just needs to be junked, pal. :thumbsup: Go out and getcha new one.
Discussion Starter · #11 ·
do they have dual voice coils or single? do you have a model number on the subs?
1 - 12 of 12 Posts
