Studdering at 65mph
419 4
Ok i got an 02ho 6speed. 150 injectors, 62mm phatshaft. Edge comp, and a smart set on 6, duration is turned all the way up and no timing set with the smarty. So when I'm going 65mph in 6 gear i get a studder but as soon as i bring the rpm's up it goes away. I already replaced the tps with the timbo app. Am i just running to low of an rpm or something else wrong? Thanks for the help guys.
Is the Check Engine light on?
No check engine light is not on.
You might try shutting off the Comp or Smarty one at a time to see if one of them might be the problem.
I guess ill have to try that tomorrow. Thanks
