Any ideas?? Perhaps I should have posted this in the powertrain section. The noise almost has the sound of a belt slip, but it's coming from under the dash.
Do you still have the fire wall covering stuff? If not then its just you turbo whistle bouncing off the block and shooting over to you drivers side. My buddies is like that it sounds like a damn cat is crammed between the motor block and fire wall.I'm getting a strange noise from under the dash when boosting over 15 psi. It's on the driver's side and has an odd, squeaking sound to it (tough to describe), only happening when accelerating hard. I'm not familiar with the climate control system, but I get the impression something might be seeing pressure that's not supposed to. Any ideas where to start looking? Very odd...:confused013:
Well im glad you got her fixed :thumbsup:Firewall insulation is still in place, it was just the boost leaking out of the intake where the bolts were loose.
