1 - 3 of 3 Posts
truck is 94 4x4 5 spd. has new lift pump .stock & works great!!! the other day on way to work it stalls & i have to tow it home! !!!all i can find is a collapsed rubber RETURN line at tank. so i fix & bleed and its running again! my question is can a flattened RETURN line do that or did i miss the real cause ??? thanks for any help!!
thanks tom i guess i should have been more clear. the return line from the engine was kinked flat because of improper routing . i was wondering if the pinched line could stall the motor? ty!
1 - 3 of 3 Posts
