1 - 13 of 13 Posts
i like the superb single cause it upgrades into the twins, and spools alot faster then the special.i need more though, but as you can see , i aint complaining. running good at the track, but im topped out as far as air goes. running sw5, and seeing 1550 at the end of a run. dont forget 3rd gens like mine run over 1400 deg stock.if you can afford it just get twins. what are your goal's for the truck, and how much can you spend
mulisha hit it right on the head, the SuperB is a great starter turbo that can be upgraded, and olywrench is right too w/ the right combo it can push some serious air, they use an Extended Tip design that allows them to use a smaller intake housing while pushing the same about of air as a larger turbo.
the superb is the top turbo for r700 kit exactly as it is,it is good for 700
Discussion Starter · #10 ·
What size exhaust housing is on the super B? 64 or 71? The think the Super B makes a good gen 2 turbo but maybe not enough for a 3 gen without it used as twins. I also think that its exhaust might be a little restrictive in a twin setup on a 3 gen
go to the bd vendor section and look for superb threads,i think the sizes are in there
turbo
This is all great information, olywrench I wish I could've bought yours:w:
1 - 13 of 13 Posts
