1 - 14 of 14 Posts
does anyone know the quickest time for a truck with a stock turbo?
preferably a 24v record, but any times you post up will work. i was just curious to see how fast you could go with it.
nitrous, water/meth, and propane are fair game, but you need the factory charger......:T::T::T:
:thumbsup
My 91 D250 ran a [email protected] with stock turbo,injectors,and trans #2 only
quickest 1st gen with stock turbo
wow, thats pretty good guys. do you think i could pull low 14's with a fass, adrenaline, and good clutch?
maybe later down the add some 100 hp injectors, and water/meth.
see sig for dyno and ET .
Stock turbo, sticks, and CP3.
Should beat that this weekend also.
Just basic pump mods 4 turns on the fuel screw,fuel pin turned 90*and 3200 gs.
I just turned a 12.91 and know I can turn a 12.8 maybe a 12.7.
Your drive pressures have to be insane runnin lean I was contemplating spraying mine back in october with stock turbo and decided i didnt want to scatter mine. I think you pushed yours to the limit with nx.
I do think however I have your stock turbo on #2 alone beat with a 13.309 @102 this was with stock injectors, stock turbo, stock cp3, stock lift pump, stock exhaust not even straight piped, stock intake and stock transmission.
I do however believe the fastest 1/4 mile with a stock turbo dodge was coaltrain over on comp d with a garmon built 12valve ran in the 12.8s on #2 alone.
CREED,
What are your mods?
At that time to run those times was only a smarty with 4.4 beta and a quad x2 pressure stacker that setup ran a 13.309 @102 mph I think it could have been more with the 4.2 beta and a dr. p stage 3.
1 - 14 of 14 Posts
