I have a friend that has a 01 cummins an the rpms only show half the time,any idea:banghead:
mine does the same. about 75% of time it works. i will monitor to see if anyone knows why.
my guess is cam sensor
:ditto: what he said
Mopar1973Man.Com
Don't guess pull the error codes and it will point out the bad sensor!
OBD II Error Codes
There is only 2 sensor that could control the tach. crank sensor (if equipted) or the cam sensor. There is also a lead that goes from the ECM to the PCM for tach signals too. There is also a error code for that lead if there is a problem.
But maybe the cluster is screwy... Here is how to test it...
Cluster Testing
i will guess that mine is the cluster. will do test tomorrow, but when tach lays at 0 the attitude still shows actual rpm. lly, hope you got a solution from these guys also
Thanks for the help guys
Cummins Fanatic
Crankshaft Position Sensor. Have the same problem with my truck right now.
