1 - 9 of 9 Posts
Hey guys, have a quick question. I did some searching but came up empty. Anyways, does anyone know what our 5.9 24v Cummins can handle in HP w/o doing anything internal? I am basically wondering how much horse power can safely be added before I need to start bullet proofing the motors internals. Once I upgrade my tranny, I'm just looking to add a programmer and maybe do a few other things to get close to 500hp. Thanks in advance.
Your trans is the weak link. Spend the money to build it for a level above what you expect, as the power is as addictive as Crack.
As Me said, the bottom end is not to worry about. After you get to a ceertain boost/RPM level, you will need head studs, possible O ringing the head, valve springs & pushrods.
Outside of the O rings, you can do the rest with never removing the head or opening the engine.
Ed
until you intend to rotate at 4K plus. you stock lower end should be good upt o roughly 750-800hp conservatively.....anything can happen, but a 900hp stock low end can survive a respectful driver for quite some time.
Thanks for the input guys...yeah currently looking into either a tranny from Firepunk or get someone local to build it. Reliability is my concern since this is my DD/work truck. I want the power but I also need it on a daily basis so drivability is also a factor.
PA VICE PRESIDENT
500 is fine for stock motor. A good setup will be programmed,injectors and turbo. Going with a bigger turbo will require head studs. Im running injectors and edge and im at 420 to the wheels. 400 to the wheels is a good start. Im happy as it sits now but come summer time Im gonna get a turbo for it
what turbo are you looking at? id like to be around 450 to 500 so Ive been checking out either the Super B SX or the Aurora 3000. I saw they have the super b sxe now too, but havent heard if it spools as fast as the SX, the special seems a little too slow to spool for 500 hp
You do not have to worry about internal engine.
Supporting Vendor
the billet 57.1mm/65/14cm gated turbo ( also called a 58mm for marketing reasons) is a great turbo for 450HP, 500HP is a little bit of a stretch. I prefer the gated housing on the super B or the SXE2G576514G40 (our DAP part #) its a smaller exducer than the cast 57mm and it flows 10% more air at 66lbs/minute. It could support 500HP, but would be better looking a a 62/68/12 for the 450-550HP range unless you towed a lot and often and had a goal of 450HP.
the 57mm GXE is MUCH better than the k27 for applications over 400HP.
1 - 9 of 9 Posts
