So today I installed my DIY big hose fuel line from the fuel filter canister to the cp3 with a fuel pressure gauge. At idle it shows between 8 and 10 psi and between 8 and 9 psi when cruising down the highway. Although once I go to WOT the pressure drops to about 4 to 6 psi, is this normal? Or is it a sign of a weak lift pump? Not that it really matters at this point, on the 15th I'm getting a FASS 95/150 lift pump installed, I'm more curious as to if it's a sign of a pump getting weak or if that's a normal pressure drop. I had a shop tell me that the lift pump is getting weak, but I have no clue what pressure a stock pump runs at and what kind of pressure drops are associated with throttle positioning.
