Yes, it's called a Dorman fitting, you get one with the AD100, I'm using it now but if you run your pump return to the filler neck you'll have the same problem I'm having.There is a fitting that goes in place of the factory lift pump, that will allow you to bring the feed line into the factory fuel filter housing. :thumbsup
Have you figured out where the return line needs to go.
Run the return line into the OEM sender port on the in tank canister. You'll have to remove the canister to do this. Unplug the OEM plastic tubing from the return port and plug it into the OEM sender port. Plug the OEM return port. This will keep the canister bowl full of fuel so as not to have 1/4 tank issues. Drill a new hole in the top of the canister for the draw straw. This becomes your new sender line. It's easier said than done, which is why I haven't done it yet!!:w:but if you run your pump return to the filler neck you'll have the same problem I'm having.
I'm going to modify the canister, grind down the ribs of it and use a draw straw that uses bulkhead fittings. This will become the AD return line, it will be filling up the canister all the time instead of just pouring back into the tank.but if you run your pump return to the filler neck you'll have the same problem I'm having.
I'll be doing it once my fuel gets low, will probably use this draw straw from Glacier.
Glacier Diesel Power - Product Detail
For a few extra dollars they'll send it with 8AN fittings to match the rest of my AD setup.
In the meantime, here's some pics of the canister (note the tie wraps used to release the Dorman fittings) ...
Fisherguy_photos - Photobucket - Video and Image Hosting
:woot:Ok you guys just fixed a problem I didn't know I had until 2 nites ago, when I run my tank below a 1/4. that makes perfect since. It was designed that way to control the pick up from starving as the fuel moves from side to side & front to backRun the return line into the OEM sender port on the in tank canister. You'll have to remove the canister to do this. Unplug the OEM plastic tubing from the return port and plug it into the OEM sender port. Plug the OEM return port. This will keep the canister bowl full of fuel so as not to have 1/4 tank issues. Drill a new hole in the top of the canister for the draw straw. This becomes your new sender line. It's easier said than done, which is why I haven't done it yet!!:w:
When I started this I just want to know how to run fuel threw the stock fuel filter housing (canister) :lol3:
ShagginwagonAfter re-reading the thread I didn't find an answer. How do we incorporate the stock filter into an AD system?
Yeah, sorry we got a little off topic but kinda related. Gettin' back to your original question. Was it answered? After re-reading the thread I didn't find an answer. How do we incorporate the stock filter into an AD system?
Ok I installed a new draw tube in the stock canister. the 1/4 tank problem is still there. when the tank gets to a 1/4 and you stop or make a left turn the pressure drops to between 3 and 5psi. what do I do now? any ideas?You could modify your stock canister to have the draw straw suck from it, but you'll also need to plum your FASS return line into it or you'll have issues with the canister running out of fuel like I'm having right now.
I used a Liberty canister and am using it's stock feed to my AirDog but have my return going to the filler neck. I'll be moving it to the canister, read about it here:
Thinking of trying the Liberty Canister and Airdog 100?? - Dodge Diesel - Diesel Truck Resource Forums
Cool, thanks for the heads up on that one.:thumbsupShagginwagon
From diesel dan, to incorporate the stock housing in the AD system there is a plate that replaces the stock lift pump on the CR's the # he gave me was FP-1001. It came in the kit for the 98.5 to 02 ask your dealer. I hope this helps
Did you connect the oem return tubing (in the canister) to the oem sender line (your new return line)? Simply dumping it into the canister isn't enough, from what I've read, to keep the bowl full.and I did take the return out of the filler neck and put it on the old supply line into the canister.
there wasn't a hose on the oem return (in the canister) just a 3" nipple. the oem return (from the engine) is still connected to it. the FASS return is connected to the oem supply and the new straw is drawing from the canister. Now that I think about it, the stock supply draws from the buttom of the canister that means that the fuel from the FASS return is being pushed threw the canister back into the tankCool, thanks for the heads up on that one.:thumbsup
