How much should a brand new stock fuel pump and new fuel filter be able to keep up with?
I put a new fuel pump and fuel filter into my fuel system and then filled the fuel tank up COMPLETELY to make sure that It wouldnt have an issue even if there was a crack in the draw straw. Started it up and it now idles at about 10-12psi. But the moment I accelerate moderately i drop to zero psi. I believe its all stock minus a superchips tow tune. The only difference I see with the new fuel pump is that the psi goes back to 10psi faster when I let off the throttle.
Is this normal?
Is this normal?
