Same here. I wasted the money on a K&N cold air and absolutely hate it!!! I also hate myself because my dumbA$$ tossed the OEM box and inlet tube in the trash. I found a box locally but the inlet tube, it'd be easier to locate a legitimate biden vote than that duct. I can suggest that you should look on www.car-parts.com because there are plenty throughout N. America, all ate too far from me in Michigan. Check it out....Looking for a stock air box. thanks!
Get a cool hose. They work better and are designed to use oem airbox with out the baffled inlet tube. About $100Same here. I wasted the money on a K&N cold air and absolutely hate it!!! I also hate myself because my dumbA$$ tossed the OEM box and inlet tube in the trash. I found a box locally but the inlet tube, it'd be easier to locate a legitimate biden vote than that duct. I can suggest that you should look on www.car-parts.com because there are plenty throughout N. America, all ate too far from me in Michigan. Check it out....
YepThe OEM 2003-07 intake air hose (from the air box to the turbo) is a complete mickey mouse waste of time.
It has a plastic baffle in it, it is of various diameters and numerous steps. Even if you gut it, it is useless.
Here is a much better replacement. I had one of these in black for years. The blue and red colors are lame.
It's a simple, smooth, heavy duty silicon hose.
Cool Hose Intake Hose 03-07 5.9L Dodge Cummins
Check out the deal on Cool Hose Intake Hose 03-07 5.9L Dodge Cummins at Diesel Power Productswww.dieselpowerproducts.com
Shoot me a pm with your price, and I will do some research to see if it fits. Where are you located?@twildman I have one that came off of my 2008 6.7, I'm not sure if it would fit 110% correctly or not, they looked fairly identical from a quick glance. I have both the box and the tube arm and the box has a new fleetguard filter with maybe 5k miles on it that I will let you have as well. If you are interested in it, let me know, I am willing to part with it for probably considerably cheaper than anything that is listed online.
If you choose to get a new one, I totally understand that too. No big deal either way, thought I would mention it.
L0L I did the same but kept my OEM parts, trashed the K&N parts when I switched back years ago.Same here. I wasted the money on a K&N cold air and absolutely hate it!!! I also hate myself because my dumbA$$ tossed the OEM box and inlet tube in the trash. I found a box locally but the inlet tube, it'd be easier to locate a legitimate biden vote than that duct. I can suggest that you should look on www.car-parts.com because there are plenty throughout N. America, all ate too far from me in Michigan. Check it out....
Where are you located? Thanks!I have one from my 07 5.9 if the above box won’t fit. I am replacing engine with a 6.7 with a 2nd gen swap so won’t need it.
I am in Fort Myers, Fl 33905Where are you located? Thanks!
