Thanks to this forum I found an '05 with 131k I liked and ended up buying it. It's not without a few issues that need to be sorted out.
I believe it has an injector that's gone out or is on the way out. Truck runs really well, fires right up cold or hot, pulls hard and smooth, and passes blow-by test with flying colors.
So far I've ordered a set of Industrial Injection +60 injectors, new feed tubes, and new feed lines. I also ordered a Cat 2 micron spin on fuel filter conversion kit and a Fass Titanium 95 lift pump kit. I can likely do the injectors and filter conversion myself but it looks like the tank needs to be dropped to install the Fass and that's out of my area of expertise so I'll likely have a local shop handle that for me.
Not looking to hot rod the truck just try and get as many trouble free miles out of it that I possibly can. Are there any other essential mods I should be looking in to?
Clip of warm engine idle: https://photos.app.goo.gl/G9Du1NhqZfZukRNe8
Clip running down the road holding steady speed: https://photos.app.goo.gl/Z7XWQsg5p51qUHf37
0-70 pull: https://photos.app.goo.gl/FC84yWrZuxtq9rrRA
