Does anyone know (and preferably have a source to cite) what the offset is on the stock 20x8" black wheels that come on the 2019 2500's with the Night Edition?
I'm trying to do some calculations to see if I can fit my 22" x 10.5" BMF Novakanes which come with a -25 offset. I think it may be close if I go down to 33" x 12.5".
I added my shots for your research.
Gives you a bit of idea. So I have a 20x9 0 offset Hostile Jigsaw
I’m running a 275/65/20 tire and I have (had) rub at full lock. Heat gun and some melting and I’m good to go.
I am stock height by the way.
They told me a 10 wide wouldn’t and we test fitted a 20x10 -19 and I couldn’t get a full turn out of it.
Maybe with a larger negative back spacing and a 33 being smaller than my 275 and you’ll have different luck but no doubt it would look good if you can fit it.
Plug in your numbers and it will give you all the data points including any change in scrub radius.
I used this for wheel/tire fitment on my Audi last year and it was spot on moving from factory 235/45/R17 to a different wheel & offset and 255/40/18's.
Related Threads
Cummins Diesel Forum
8.8M posts
379.2K members
Since 2005
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
