i have changed all 6 injectors and new tubes torqued them down to the correct specs and still geting a little white smoke on start up goes away after about a min
had the injectors out couple days ago and cleaned tghe tips and re torqued them little carbon build up due to just breaking the motor in but nothing serious i cleaned them off
If you just replaced everything like that and those tests pan out, then I would say its normal. You have no cat so it's not there to catch the junk/ fuel that doesn't get burned up before the engine gets warm.
My truck will belch out white/grey smoke when its cold and even a little bit the other day in 40 degrees when I hadn't driven it for a few days.
all tips were about the same maybe a little difference but nothing substancial
Dodge Cummins Diesel Forum
