After using the "search" and reading around 200 posts I've got some things sorted out but still have some questions.I need a turbo for my truck. I just added a set of DDP150's and this summer I'll be towing an 8000lb trailer a couple of times. I live at 4000ft and the passes around here are about 6000ft.
I decided I need a 62mm turbo with a 12cm housing (I think) and I can't decide if I need a 65mm or 71mm turbine?
What difference would be noticed between a 12cm or 13cm housing?
And finally, what is the safe max. boost before installing studs? And what is the safe max. boost with studs before o-ringing?
Thanks.
Thanks.
