1 - 3 of 3 Posts
Fellas, since the steering issue is a recurring topic, I thought I'd try to start putting together a thread for sticky. Below is the immediate info off the top of my head. Please help me edit it for accuracy. Also add to it if I've overlooked something. I welcome more links you think would be pertinent. I don't want it cluttered with every thread with the word "steering" in it. Want to KISS to reduce confusion. But the question needs to be answered for reference.
Thanks yall :thumbsup
What's this about a steering recall?
http://www.cumminsforum.com/forum/3rd-gen-powertrain/145251-steering-linkage-recall.html thread
http://www.cumminsforum.com/forum/t...6462-mopar-safety-recall-h46-anybody-get.html thread
H46 Recall Notice (in PDF form)
Do have the old style or new style linkage?
4Wheel&Offroad Photo link displaying both linkages for comparison
Where are the part numbers under the truck?
On a white tag glued on the lower linkage. It might be worn off.
Is there a writeup for a DIY linkage install?
http://www.cumminsforum.com/forum/3rd-gen-non-powertrain/181227-tie-rod-upgrade-03-08-trucks.html
Does anybody have the part numbers?
* Old steering linkage part numbers:
  • Linkage - 52122362AA - 52122362AD
  • Pitman arm - (if it's not the one listed below)
* New steering linkage parts numbers:
  • Damper - 52122370AB
  • Nut x3 - 6505623AA
  • Pitman Arm - 68039930AA
  • Steering linkage - 52122362AE or AF
The above PNs supercede TSB 22-005-06
What's the difference between the AE & AF linkage?
http://www.cumminsforum.com/forum/suspension-discussion/290822-steering-upgrade-ae-vs-af.html
Do I need to buy a new pitman arm too?
Some say yes; some say no if your truck is stock to leveled. The changed angle offsets the ball stud from compressing into the lower link.
Yes or no thread with pics: http://www.cumminsforum.com/forum/3...25-08-5-steering-w-o-changing-pitman-arm.html
Your truck, your money, your choice.
If your truck has a replacement drop pitman for a higher lift, you do not need a new pitman arm.
Do I need to buy the new steering damper?
Yes.
Do I have to use the Mopar damper?
No. Aftermarkets are an option so long as you get the right mounts.
(Need help here with details)
Where can I buy the new linkage parts?
New Mopar steering linkage can be bought here:
Individual parts:
Complete linkages:
Crossover steering option:
Thuren Fabrication- Crossover steering kits
- it is not stock
- permanent change when you drill out knuckles
The write up for the DIY install is not much of an "install" write up.
I was expecting a step by step thing, that thread was a couple pics and people arguing which upgrade is better.
Some good info in your post though! :thumbsup:
I know. I figured if I put it in the wrong spot someone will have to deal with it :rof
1 - 3 of 3 Posts
