I dont see why you would need a new pitman arm. unless you have been running on a bad joint for several thousand miles. then i could see that possibly the joint is flexing so much that it will mangle the bore. I would just suggest removing the inner tierod and see how it goes in. I know on mine with 98k i had one hell of the a time trying to remove the factory inner from the pitman arm.
