1 - 3 of 3 Posts
i have searched and searched for a answer to this and before i mess somthing up i was hoping for a clear answer i adjusted my steering gear box up cause the shafts had play now some gear boxes have 2 adjust ment screws but i only saw one and i adjusted it but the center point on the gear box is off now and i cant seem to find the 2nd adjsutment screw or is there even one? am i sopose to take off the steering shaft and pittman arm and set them or what? i had an alignment done but the jackass didnt seam to knwo what i was talking about so im looking for some good info or somthing to lead me in the right direction before i mess up the gear box
On call 24/7
the only adjustment on the box is the lash, its on top, 5/8" jamb nut and an allan wrench, to straighten your wheel there is an adjuster sleeve on the drag link, two 15mm bolts, rotate sleeve untill straight, tighten bolts, done:thumbsup:
1 - 3 of 3 Posts
