yeah...it's comming from the shaft... I just called aroung it about $135 to $210 for rebuilded one... so i guess it's not to bad... do I have to replace the brace? ...it looks new..:banghead:Where is the fluid coming from. If it's a line it's an easy fix. If it's from the shaft right above your pitman arm your box is toast. New box and a steering brace. The Brace is supposed to keep this from happening and tighten up your steering as well.
do you know if you have to bleed the system after you done installing box? ...if you do where is the valve?:confused013:I replaced my steering box about 6 months ago. I had my box rebuilt by PSC and also installed their steering brace at the same time.
Truck drives better then it ever did.
Yeah you do, but no valve.do you know if you have to bleed the system after you done installing box? ...if you do where is the valve?:confused013:
yap... i got one ...(BD Diesel)... previos owner installed it...so it's improving "wondering" around road ?The brace I'm refering to is a bar going across the front that bolts to both frame rails at the stabilizer bar mounts and has a bearing and pillow block that attaches to the end of the steering shaft via a special pitman arm nut with a 1" shaft machined on the end of it. You don't have one of these do you? It is suppose to prevent this from happening.
allready replaced it with one with lifetime warranty from Shucks ($133) ... but steering pump still making noise...you think it's because i haven't bleed the system?...It's supposed to. I wonder if the box was bad and the previous owner tried to "Bandaid" it with a steering brace. At any rate you are going to have to rebuild/replace it.
Hey I was looking at your signature and i see on 2007 u got 4.10's and 2006 u have 3.73's.. How's milage compares betwen them two?? tnx.It's supposed to. I wonder if the box was bad and the previous owner tried to "Bandaid" it with a steering brace. At any rate you are going to have to rebuild/replace it.
