1 - 20 of 236 Posts
I expect to buy a new 3500 HO with aisin today. Only unresolved issue I have is srw or drw? Crew cab 8' bed, four wd, tradesman.
I will be towing up to 16000 lbs worth of a 1994 four star living quarter horse trailer, three horse. 37' overall length, 28' on floor.
I want the aisin transmission but have never had a drw and don't know if I will need that for stability on the highway or if the new srw 3500 will be as stable with that weight?.
Looking forward to thoughts on this.
Unless your pulling with the truck 80 plus percent of the time I say go srw. It will pull very good and you won’t have to deal with driving a dually and trying to park it.
What if the other 20% of the time was pulling a trailer that had a pin weight that was too heavy for the SRW? :surprise: Would your answer be "when you unhitch, it'll be easy to park."
Dually. A big boxy and substantial trailer like that and you will thank yourself the next time you hit a stiff crosswind on I-40 in Oklahoma, on I-10 over the Mississippi, or on the Roosevelt Mid-Hudson bridge. I'm sure other members will have their favorite places.
Yes, a dually is more work to live with. But once you get used to it, the only real hassles are the bank and fast food drive-thrus you have to avoid.
JMHO
Ive got a 3500 SRW and I tow about 13,500 +/- It handles that beautifully, and I could realistically see going about another 1K pounds or so max comfortably // Any more than that and I would want DRW. I feel with a 16K trailer you are solidly in DRW country. I wouldn't even look at a SRW.
I think DillonJM asked the right question - the answer to which points the OP in the right direction. The replies favoring the DRW are of the sort get enough truck to do the job - (aka, no gun is too big) - hard to argue against that. But I think, by the very nature of the question the OP already knows that. The OP also knows he'd experience disadvantages to a DRW - what he needs to figure out is, in his case, is there a quality solution - quality meaning, "meets requirements". Personally, I advice the OP not yet jump on the DRW solution - he does not want a DRW if it is NOT necessary (too big a gun is sometimes left behind and you find yourself without a gun when you need one). OP's prior experience, which DillonJM asks about is relevant. If his prior truck was DRW, and he's wondering if it's practical to drop down to a SRW, it's likely marginal at best. If his prior truck was SRW and marginal, it is possible a new SRW would do the job .
So with all that ing - something totally unrelated scratched one of my nerves today - let me add another possibility. Very likely converting to 19.5" wheels would give him a SRW truck without the negatives of a DRW, and seems to me a pretty good option/solution/improvement/backup plan to make the SRW fit the job 100% of the time, without having to drive a DRW 100% of the time.
If you read the other thread similar to this, I'm on the SRW side of things, would only buy a DRW if I absolutely needed it. It just depends...do you need the payload that the DRW offers? nlol and DillonJM have the best feedback above...
White Lightning
Until the OP states the pin weight of his 37' LQ 3H trailer, I'm going to guess that a DRW will be required.
Having pulled some of those before for customers, I can guarantee ya that the pin weight can get brutal fassssttttttt when loaded up, due to the trailer axles being so far rearward.
But, then again......I’m just a dumb ol’ truck driver.:grin2:
@Jimmy N.
@Jimmy N.
Yep, if that horse trailer looks like that, your pin weight is going to limit out an SRW pretty quick. I get away towing 22,000# goose necks with with heavy equipment on them with a SRW because the axles on the trailer are far enough forward that I can center the machinery over the trailer axles and get my pin weight down to 3000#, which is o.k. with my spec'd Tradesman.
Dang, Brockman, that trailer is at least 5 feet longer than mine, and likely heavily optioned, too. No pun intended.
Having the axles back where they belong sure makes it tow nicely, but, I wouldn't want to try pulling it with a SRW.
One of these days I should find out how much weight it puts on the drive axle. It's a lot, that I do know.
P2609 Fanatic
The desire to under-buy these trucks is certainly a strong one. Even though this is a SRW or dually question it Helps me understand the massive popularity of the 3/4 ton class trucks and how frequently the are purchased and used when a one-ton would have been the better choice.
According to the OP’s post the truck has already been purchased.
I hope he reports back with a follow-up and a few pics of his new truck (with trailer attached).
Keep us posted Montana and good luck with the new truck. :thumbsup:
White Lightning
If you look hard enough.....you can tell that this one has one slide out under the awning. There was another slide out on the opposite side, for a total of two. Ol’ White Lightning handled this one with ease, as it was a brand new unit ($75,692 invoice) and was dry but I could see it getting way out of RAWR on a few trucks.
32’3” floor and 40’3” overall length, 4 horsey, electric jacks, blah blah blah.
Hmm, it looked longer. That's only 2'3" more than mine.
Thankfully, mine is void of slide-outs and such. It's almost hard to find trailers without them these days.
But, I can put many, many horses in the 20' garage.
1 - 20 of 236 Posts
