1 - 13 of 13 Posts
When i put my truck into rev. I hear a squeaking noise like the shocks or something. Its pretty loud and noticable and i cant figure out what it could. But this only does it when i am backing up in Reverse Gear?? I slap it into neutral when im moving and it Stops? i dont get it? Guys what could it be?
Soot Sniffer
Really, i thought it would be something else because it was just happening in reverse gear. But i could try that. how do i go about changing U joints??
Soot Sniffer
1. Find out which u-joint it is. Chock the truck and put it in neutral. Wiggle the driveshaft and look for freeplay in any of the joints. While you're doing it, you might as well change them all on whatever shaft has the bad joint.
2. Remove said driveshaft.
3. You'll need a torch or another source of heat. Heat up the yoke and you'll see a bunch of plastic come oozing out. After all the plastic is out, use a press or a bench vise to press the old joints out.
4. Clean yoke of any remaining plastic/rust/other crap.
5. Install new ujoint with the press/vise.
6. Grease ujoints
7. Reinstall driveshaft.
definitely the ujoints. I just replaced mine and it was making them same noise. goodluck Fixing them.
wow this sucks to see because i couldnt figure out why mine was squeaking either...dangit
Soot Sniffer
Don't worry, the u-joints are cheap and this is a pretty easy fix.
mine were 42 a piece and i have 3 of them since its a 2wd
What Ujoints are you buying bud?? That is what the front knuckle on a 4x4 cost. These are about $12-25 depending on what you go with.
Soot Sniffer
I put Spicers in mine and I think they were 22 a piece.
Presicion bought them at oriellys I've always ran precision I guess that why I bought them. They got a lifetime warranty
I was hearing the same squeek on mine. I've been thinking it was the brakes for the last week or so. After seeing this thread i checked the joints and found the problem. Sure enough its a U-joint. Thanks Guys.......:thumbsup::thumbsup:
1 - 13 of 13 Posts
