1 - 3 of 3 Posts
I have a 08 3500 heavy duty Quad 6.7
hooking up a 10.000 lb 5 th wheel with 2000 lb pin weight would it be wise to invest in air lift springs or any spring helpers.I am new to pulling a 5th wh.
tis is not a drw truck
With that light of a trailer and pin weight, you should be fine as it is. Being a 3500, it should have helpers on it from the factory.
That shouldn't be an issue at all. My camper weighs in at 17,500 with some water in the tanks for dry camping and I towed the first few trips w/o airbags. I hooked to a 31ft regular 5th wheel (not a toy hauler) and the truck didn't even know it was back there compared to my heavy rig. I didn't even blow the bags up beyond the the 5psi minimum.
Tow it for a while and if you don't like the way it sits spend the few hundred dollars and put the air bags on it. I like my bags and when I tow the camper I only put between 30 and 40PSI depending on how much water I end up carrying. Everything rides level at that point. Honestly, It towed great without the air bags but I kept getting flashed because of my lights and I wanted to be able to shift some weight back up to the front end by leveling back out. Seems to have worked great for me. I have towed nearly 4k miles this year and it just sits up and rides.
1 - 3 of 3 Posts
