The Super B Special is a 64mm (64/71/14), that's probably why they list it with 200hp injectors. This setup is manageable if you tow light to light/medium. This setup would be a little smoky when towing which you may regret. Can be smoky when not towing, however, much easier to contol smoke without the added towing weight!
The 62mm with 150's or less is more in line for a tow rig.
Ideal high hp tow rig will have twins. Of course you can have fun with the
2nd combo you listed.
I also believe DAP will work with you to come up with other combo's that save you a little $$.
I would work head studs into whichever combo you choose.
