1 - 10 of 10 Posts
Can somebody help describe the wiring for the speedometer? I have a 92 W250 and my speedo stopped working which in turn caused my overdrive to stop also.
Where does the speedo connect to, transfer/tranny or rear diff?
After that what do I need to do inn order to diagnose the problem?
Thanks.
First off replace the first relay on the fender it's the ASD relay .Then make sure the speed sensor on trans is good . It could be alot of different thing's .Could Also be your TPS .
Check the VSS at the transfer case, drivers side, 2 wires, you'll see it
Any chance you can share a picture to help identify. I've seen a few relays on the fender and to make matters worse this is a totally new topic for me. Thanks.
So the rear differential is out of the question? It all comes down the transfer or relay on the fender?
Do this Swap the relay's around and see if that help's . then have the VSS tested and go from there . send me a E mail I can shoot you some Pic's tomorrow .
[email protected]
Reactions: @firstgen4x4
I need help to locate on a 2wd
I have a 92 2wd. Where do I find the speed sensor since I don't have a transfer case? Is it the one on the rear diff or is there one on the tranny? I think the one on the rear diff is my abs sensor, right?
Pics are helpful.
it will be in the trans, not the rear diff.
I found it it was on there but it wasn't screwed on very tight. Would that keep it for me working. it was on hand tight
that will definitely keep it from working proper. you want it clean, dry, and tightened down to work right. good luck!
1 - 10 of 10 Posts
