1 - 2 of 2 Posts
Hey guys I am new to the forum and have a question regarding my speedometer. It is a 1993 W250 4x4 5.9 with gertrag. I had the tranny rebuilt and ever since then the speedometer has not worked. That is all fine and good and I have driven it in this condition for over a year now. This weekend however the thing started working if only for about 5 miles before quitting again, even the cruise control came back. Long story short, now I want to fix this and it is driving me crazy. Type A kinda thing....Any ideas where to start? What would cause it to start back up again, and then just as suddenly stop? Thank for the help in advance.
The plugs on the tranny are most likely the culprit. When my speedo quits, I clean those connectors and everything is good for a year again. Depending on which one is loose/corroded/wet, you can have no speedo and no cruise or no speedo but cruise works. It is fed, pulse unit plug to cruise. Return wire from cruise to plug to speedo. 2 Bosch or Deutz connectors near the tailshaft. Also. make sure the pulse generator is properlty mounted to the tranny.
1 - 2 of 2 Posts
