Nope, VIN locked.Bump, I'd like to know too. Can a smarty reprogram the speedo and then still be used on another truck or does the "vin lock" apply here? How about the hypertech programmer?
My ScanGauge II can be calibrated for oversized tires and report corrected speeds... :thumbsupI've got an Edge Juice w/Attitude, but currently have stock sized tires so I haven't messed with that adjustment. Will it correct the dash speedo if you make a tire diameter change? That'd be great since I eventually plan on putting taller tires on it!
I realize the Edge unit can display speed, but I'd rather not use up one of my four display quadrants for that. I'd rather get my speedo re-calibrated at the dealer...
Tommy
Odd. Mine will (model 3705 with software version 1.04). I am not too fond of its piecewise linear tunes and it is a little flaky when it comes to clearing codes but I have confirmed the speedometer correction in all three tunes with my GPS over a long period with the cruise control set on the interstate.I know the superchips tuner will not reprogram the speedo without a tune being installed as well. Just something to think about if you stack.
Well, my Edge can display corrected speeds, but I want my speedometer to display correctly (for a variety of reasons). I didn't think the Edge could control the speedometer, but thought I'd ask.My ScanGauge II can be calibrated for oversized tires and report corrected speeds... :thumbsup
But you'll find out the larger tires will kill your MPG.
As for me I'm head down in size next set... I'm going to aim for a 235/85 R16 which is still a 31 inch tire but it will be 5 pounds less in weight roughly and 1-2" inches narrower... :w:Well, my Edge can display corrected speeds, but I want my speedometer to display correctly (for a variety of reasons). I didn't think the Edge could control the speedometer, but thought I'd ask.
The only thing I know for sure that works is going to the dealer for a flash, Smarty, or SuperChips programmers...
Yeah, bigger tires kill mileage, but I'm only planning on 33's to 34's, nothing "big" and certainly not a mud terrain (which kill mileage even worse). I'll certainly run smaller tires than what's on my Jeep.
Trust me you'll see a difference... Like myself I've got a set of Cooper STT (265/75 R16) and my stock set of Michellin's (265/75 R16). Just the weight difference between the Cooper STT and the Michellin's is about 20 Pound per tire. But that amounted to +2 MPG gain switching back to the Michellins for the summer over the Cooper's...
Now couple the size change (rolling resistance) and weight of the tire it will show... There is no way to cheat physics
Tommy
Not bashing here, but that's worth it to me. Last stat I heard, the average american drives a little less than 15,000 miles per year, so most peoples fuel cost would be less. If I wanted small tires I would get a car, i'm going 35's next on mine and I expect to see the mpg's drop and the looks and comments go up :thumbsup But this is coming from a guy that doesn't understand why in the world they make 2wd trucks$356 more fuel consumed a year for larger tires...
