Gone Fishing!!
I have my old dealer asking me about there cab-n-chaise not being able to go over 69 MPH? Does anyone know about this? I left the dealer to get into trucking and working on diesels here on the side. I left before the 6.7 came out and I'm not to much up on them as far as programs and all. The tech they have now is a Saturn tech and has no clue. I haven’t used a DRB III yet on them but wanted to see if anyone else knows about this and is there anything we can do to change the speed limit.
Thanks Chaz
My 4500 and 5500 are 76mph speed limiter, and as far as I know there is no fix yet. Maybe the smarty as Bob said somthing to Marco about this seen it in a post somewhere.
flgc
I know more than a few guys that have the Sterling Bullets in the 4500 and the 5500 have the same 75 mph limiter as well. I understand that its the 19.5 tires and the speed rating those all have...
The BullyDog Power Pup will let you up the speed limiter on the 6.7 in the 2500/3500's so maybe it will also let you raise it in the C&C's
Gone Fishing!!
Thanks everyone and I know some of you are saying why would you need to go faster than 76 mph in a 4500 5500 truck:thud: It was just a question if it could be raised or not.
Does anyone make a programmer for the 4500 or 5500 trucks? I can't say for sure it would be the same as the 2500 and 3500's.
Decoder Ring Specialist
The 3500 C&C/4500/5500 to the best of my knowledge all share the same platform/power ratings WRT the engine, ECM, and fuel mappings. They're all DEF units so anything that works on the 3500 C&C *should* apply to the 4500/5500 without incident. Where they differ is in suspension, frame, transmission, and front/rear ends.
