well im confused on what to get!!i want the front end to be a lil higher than the back!yet be stock height because i want faster times.well i heard that spacers move the axle and you have to buy something to adjust them with right?WHATS THE BIGGEST SPACER I CAN GET?and there is also a KORE front space lift right?whats the difference and whats better?i got 20x10 American racing with 305/55r20 and they clear no problem,just wish they stuck out more
2wd or 4wd? It's not in your sig. Either way this won't change how far your tires stick out. That's all in the rims you're running.
T-BONE
Well I have a 4x4 dually. And from my investigating, on a 4 wheel drive you should be able to run a 2.5" or maybe 3" spacer up front without having to change the arms. If you go any bigger then you have to change the arms and put adjustable ones on. I have a 2.5" level kit and mine sits perfect level, until I put my camper or a gooseneck trailer on....
I had a set of ready lift spacers untill recently when i ditched them for a kore suspension, in any case i had no problem with the spacers and they leveled out the truck nicely only adjustments i did was an alignment, same story with the kore lift
well i was wanting to get my front end a lil higher than the rear since when i get on the throttle the front end lifts pretty damn high,and plus the front end higher a little looks better.any adjustable spacer or lifts?
