imo. its too small to run as a primary. if you wanted to run it as a single, your going to need ALOT of fuel to spin it.
And what would this cost??if i were doing it... get a 14cm turbine housing (call columbus diesel), get it machined to fit the 78mm wheel, a t3-t4 adapter, turbo drain line, hx40 down pipe, and all the inlet piping.
im running ~250hp injectors now. i have seen guys running 275's, 300's, and 320's. a 250 is the max i would run on a sovp.Would it be benefical to go to a bigger injector than 200's?? And what would be the largest I could go with on an SO VP??
its been a while since i got quotes, but if i remember correctly...And what would this cost??
