sounds like it would work...i install a gorend vavle body in my 01 and really like it, i plan on doing the same to this truck....the vb cost a little more but the labor was free..
Minor differences, nothing that would effect what they are aiming to cure with this kit.The valve bodies are different on the 03-04.5 48re to 05-07 IIRC. I would check with sonnax.
Ok I knew there where some differences...off the top of your head you would not happen to know what they are? Sorry for the hijack....Minor differences, nothing that would effect what they are aiming to cure with this kit.
The differences in the early and late Transgo kits indicate they change the routing of the fluid dump slightly in a couple places. There used to be a vent to evacuate the circuits and now there isn't. IIRC, we drilled a hole where there isn't one and I believe a restrictor plug in another.Ok I knew there where some differences...off the top of your head you would not happen to know what they are? Sorry for the hijack....
Yeah, I understand what you're saying but I don't want to piece together a transmission. I'm going to eventually buy a Goerend unit, but not right now. For now I just want more line pressure to reduce slippage, flow in park, and a few other things.i still think a just buying a vavle body from gorend or suncoast takes all the guess work out of it...jmo
Sorry, I'm just getting back to this. My issue was I wanted to raise line pressure, and you're saying that the Sonnax kit won't do that? I had my heart set on a TransGo before I went into that shop to talk to the tranny builder.
Where it all started for me is, like a dummy, I didn't check the tranny fluid in the truck when I bought it last month. Now checking it the other day it's waaay over full, and it's dark red. It should look like blood right? It doesn't smell burnt, but it does look beat up. Also, off the line the truck bangs gears pretty good. Crusing and going to WOT the transmission get's confused, sounds like it's slipping, etc. Leaving the line at light throttle the transmission just seems to damn mushy for my taste. I had a transmission built for my Grand National and at light throttle it bump gears ever so slightly and was a really positive shift, and the harder you got on it the harder it shifted. I really liked that, and that's what I'm looking for.
So I should just buy the Transgo kit (since I don't want a VB right now) and forgo the Sonnax kit?
