Well I've been having problems with my 96 not wantin to crank up and not turn off with the key.
So i took the solenoid off and manually lifted the lever and told my friend to start the truck. well it started. but when he turned the key off and i pushed the lever down it was still running!
What the Heck is Wrong Here?
is the shaft on the pump actually turning (the key could have fallen out)
Is the wood ruff key the one that holds the bottom of the the solenoid shaft on. if it is then its there. i belive its movin
its not the gov springs...
Pull the linkage off of the pump shaft and make sure the key is still there. it can be gone, but still appear to function because of the splines, but they slip and its not actually moving the shaft all the way
