No, I didn’t because the transgo instructions said it wasn’t necessary with tv cable equipped models. But now that I’m experiencing the shuttle shifting, I guess I’ll install that spacer…..or go back to the metal style governor sensor. It wasn’t doing it with the old governor sensor. Weird. And the metal style does seem a lot more robust to me…. But I don’t know.In your first post, 4th picture, there’s a spacer that says it’s to prevent 2-3 shuttle shifting. Did you install that spacer?
Another thing is I made my own gasket between the governor body & valve body…. I couldn’t find a quick replacement. I’m wondering if the material I used isn’t right & it’s letting pressure escape? I got all the holes perfectly cut out & the material is for high heat applications so I doubt thats my issue.
