My vehicle is a 2004.5 2500 Cummins with the 48re.
The truck had a transmission rebuild right before I purchased it and everything works fine.
I want better shifting & to make the transmission last longer, so I decided to install the TransGO sk48re kit along with the following Sonnax parts: manual valve 22771-09, lube regulated zip valve 22771a-02k, front servo cover 22827-01, billet piston kit 22841-04k. A DNJ gm governor solenoid kit was already installed by previous owner.
I currently have the valve body apart and have read through the TransGO shift kit instructions and have decided NOT to do the following steps (please correct me if I’m wrong):
I won’t drill these holes:
I will not perform this notch, since I’m using the Sonnax valve:
I will not install this green spring:
I will not install this gold spacer (I have tv cable & no issues with shuttle shift):
I will not grind the switch valve:
I will not use spring, shim & PR valve from kit since I’m using Sonnax valve:
I will perform the rest of the steps, although I’m unsure if I should drill this hole or not:
Is my plan flawed somehow? Thanks for any input!
