EDIT December 2023: Cummins roller itself is the problem. Only real solution is a flat tappet conversion.
See new thread here! https://www.cumminsforum.com/threads/flat-tappet-lifters-for-2019.2588287/
Alternatively, the expensive and custom Jesel rollers sold by Wagler can be considered a solution, but there currently is little real world knowledge on robustness of this setup. Choose carefully.
Been doing some digging and someone (Wagler) is finally offering a solid roller lifter conversion for 2019+ trucks.
It uses the factory ISB adjustable rockers, but just replaces the internals of the hydraulic lifter with a solid spacer. Also uses custom pushrods as 2019 uses different ball on lifter and different length.
Seems like a permanent solution for when the hydraulic lifters go bad.
