101 - 120 of 152 Posts
· Banned
Are the Cummins cams made by garbage?
Wagler stage 1 as that’s all I knew about when ordering. I didn’t even know Hamilton had a setup.
I don't see any Cummins camshafts on the Wagler website at all.
Is it possible that Wagler is simply selling the Hamilton roller cam?
· Admin/Mod
I still know nothing
Discussion Starter · #104 ·
You have to look at this link.
Their main site is outdated.
Anyways, Wagler doesn’t give specs, that’s why I recommend anybody to use Hamilton. They at least publish specs.
Reactions: StealthDiesel
· Admin/Mod
Discussion Starter · #105 ·
that whole lifter difference in the build and detail is so odd.
Yeah they definitely redesigned something. Even the body is more machined near the roller pedestal than before, which increases cost.
Reactions: elephantrider
· Admin/Mod
Discussion Starter · #106 ·
How the tool moves the lifter into position.
Automotive tire Motor vehicle Automotive design Wheel Bicycle part
Automotive tire Motor vehicle Automotive design Bicycle part Gear
Magnet inserted into ball cup.
Gadget Communication Device Camera Cameras & optics Audio equipment
Lifted into position.
Product Communication Device Gadget Audio equipment Portable communications device
All lifted into position.
Motor vehicle Automotive design Automotive air manifold Hood Car
Drinkware Automotive tire Liquid Fluid Rim
Cam installed.
Gear Automotive tire Auto part Engineering Rim
Rockers and pushrods installed with .010” intake and .018” exhaust.
Motor vehicle Hood Automotive fuel system Automotive design Automotive air manifold
Motor vehicle Automotive fuel system Car Automotive design Vehicle
· Red Rider
2022 RAM 5500 Tradesman Crew Cab & Chassis 4X4
Your engine oil dipstick is inserted upside down.
Don‘t bullllllyyyyyyyy me; I DO NOT have OCD.
:geek:
· Admin/Mod
Discussion Starter · #109 ·
great work. that is a major job. how does it sound? nice and quiet?
Timing cover and the whole front of the truck isn’t on yet…
And I’m also doing the HVAC box replacement TSB while I have the R134 and coolant out. So now I have to pull the dash🫣.
:geek:
It pissed me off when I looked closer, but by then, I wasn’t going back out to flip it around lol.
· Admin/Mod
Discussion Starter · #110 ·
Made these with my label printer.🤓
Font Plant Rectangle Event Label
Hood Bumper Automotive tire Vehicle door Automotive exterior
All things being equal, the engine will be louder with solid roller lifters versus the original hydraulic roller lifters!
However since the engine is "lighter" and has a custom ECM tune, I'm sure you won't be able to tell.
@cumminsturbofreak what is the black clip/retainer on the cam gear?
Man I would have been tempted to install head studs at the same time.
However lack of stock and I noticed yesterday that ARP 625+ head studs now retail for US$1600 (CAD$2200). Holy heck...
· Admin/Mod
Discussion Starter · #113 ·
That is a spring loaded scissor gear. It removes lash and eliminates gear train noise.
I was thinking about headstuds, but I can’t afford that kind of expense right now for a maybe. I’m out about $3500 in parts so far. Maybe at a later time.
I should hear a difference actually because the cam has slightly different duration and timing.
· Admin/Mod
Discussion Starter · #115 ·
Ordered that stage 1 kit myself....did the jessel lifters tho...I'm local to wagler and later this summer I'll have them install them...with the change to the lifters are you @cumminsturbofreak going to run 15-40 oil again or?
Probably.
· Admin/Mod
Discussion Starter · #116 · (Edited)
WOW!
So I started it, and, boy is it QUIET! No more ticking above 1500rpm!
And as a bonus, exhaust sounds great with the cam!
2014 Ram 2500 6.7 CTD SLT
Right on man!
Not sure I would want that anti-rattle assembly to ever fail in the gear train.
KDP all over again. Hopefully it is stronger, thicker, more substantial that it looks.
The engine does sound great.
Running it at 1500 RPM to break in the roller cam and solid roller lifters?
There is for sure a break in procedure for flat tappet cams plus a zinc additive at break in time but I don't recall a break in procedure for roller cams.
Of course my experience is with roller cams in gas engines like my older 5.0L Mustang and various GM LS truck engines.
