If you can't pull the front end apart one should probably have a shop do that job then. Interested in seeing these new lifters
If you can't pull the front end apart one should probably have a shop do that job then. Interested in seeing these new liftersOf the actual cam and lifter install, I’ll do a write up.
Pulling the front end, no. Way too many steps.
Yeah I did a tech write up pictorial for 3rd gens. It was a LOT of work to complete that write up step by step!Of the actual cam and lifter install, I’ll do a write up.
Pulling the front end, no. Way too many steps. EDIT: Maybe I will when putting back together, didn’t take any pics taking apart as I was rushing as usual.
Although my thread (5.9) isn't replacing lifters, I did use the dowel trick. I was brave and didn't use the PVC pipe cut in half, but I also pulled the oil pan. Lots of detailed how to pics in my thread.With my luck, I would be ahead of the game to pull the engine oil pan as a 1st step to retrieve the inevitably dropped lifters!
Pretty much. As the special tool is out of stock, I’m experimenting with magnets holding the lifters up, but I may buy/make another tool once I have a lifter in my hand.So the 2019+ roller lifters are not able to be removed from the top and not able to be installed from the top?
And it doesn't sound like wooden dowels can be used to hold the lifters up for cam removal/installation like on the 5.9L engines?
And the timing cover still has to be removed to pull the cam?
And a special tool for installation of the roller lifters.
Lol the idea is to make newer vehicle less serviceable and more like cellphones. Last Cummins to have a tappet cover was the 98.5-02 24v.Good grief, Cummins could have made some changes with the 2019+ engines to make it easier to service the cam and lifters.
Good luck with that.holy hell…well i have an appointment for a dealership near me for next wednesday…fingers crossed
Yes.Stock valvesprings right?
Are any of the rockers galled or binding? Common on the early 5.9L CR engines..
So does this mean we need to worry about cam & lifters like the HEMI boys do and start adding cans of Molly to the oil to protect the cam & lifters?that cam wear is shocking. seriously.
I'd do the upgrade since you're literally balls deep anyway.
appreciate the documentation.
I would just keep an eye on it. If you get a borescope with flex head, you can easily check condition of your cam by simply pulling rockers and pushrods.So does this mean we need to worry about cam & lifters like the HEMI boys do and start adding cans of Molly to the oil to protect the cam & lifters?
