Truly disgraceful. Can't be called an American company anymore.
Truly disgraceful. Can't be called an American company anymore.View attachment 974900
And this makes me sad…
@krs probably thinking “told ya so.”
A special tool for removing the lifters that are only in the 19+ engines? Did you buy that tool and if so what does it look like?Lifters and/or cam. The lifters come out through the cam hole and a stupidly expensive Mopar special tool is needed to do the job.
I decided to go with a Wagler Stage 1 tow cam as I’m not putting a hollow China cam back in.
If you can't pull the front end apart one should probably have a shop do that job then. Interested in seeing these new liftersOf the actual cam and lifter install, I’ll do a write up.
Pulling the front end, no. Way too many steps.
Depending on your desire for problematic emissions especially when one uses their truck in extreme cold temps in remote locations thus lots of idling happening rule out the newer trucks.Every gen has one problem or another. FWIW, I prefer the new trucks with a couple fixes then old trucks with much more fixes.
Do you think the one without the oil groove will be as good?So surprise surprise, the new lifter has NO oil groove or hole.
And I was wrong! Some of the new ones have smooth necks and the others have grooved necks.
And actually, ALL new lifters are MADE IN MEXICO.😂
LH is new one made Oct-2022. RH is original 2019.
They most likely won't say anything. My dad had his Cat C3406B engine rebuilt by a reputable shop and they used all CAT parts. 5000kms he was having half the engine rebuilt because one of the redesigned cam follower clips had failed and did a lot of damage including destroying the cam. The clip failing allowed the cam to rotate 90 degrees and the rest is self explanatory.Someone at Cummins must know what is going on with the changes in their hydraulic roller lifters.
How would someone contact that person?
Its not accidental that the newer the vehicle the bigger the piece of s***. It's all part of the "you'll own nothing and be happy eating your bug sandwich."Cummins definitely wouldn’t disclose anything. I even called them to order these lifters direct, and they stated Chrysler has exclusive rights to purchase them. It’s pretty obvious who spec'd out the hydraulic roller setup and CP4s…
