I have a 1996 Ram 2500 it has the 8.0 V10, I have these codes
P0743- TCC
P0500-VSS
P0152- 02 sensor
P1762
my question is, the valve body has been replaced, now I have these codes ( I need to delete and then see what pops up) but I finally got it all up and going, ) it was starting out in 2nd gear and always after starting it would shut back off) now it seems to need the TV cable adjustment, I did what I could but I am sure I need to play with it more to fine tune it, but inside the transmission and then outside ( the cable) is it necessary to adjust both ?? And the solenoid issue, I was advised to get the GM version but I am not sure what that part or item may be found at, also the ABS light is on and I replaced the rear sensor On the shaft so many times it doesn’t go away; is that something that has to be manually deleted or would it go away on it own if fixed ?? Now I purchased the truck starting off in 2nd and did all that work with the rebuilt valve body ( I think I was sent a pos power washed from a salvage and told it was refurb) so with that said, I shall pull the pan off again and replace them again or is there something else or a adjustment I need to start with ?? It does seem to shift and drive I had iton highway and city driving and no high rpm but yet it still seems it starts in 2nd but that could just be the TV cable needing more adjustment
P0743- TCC
P0500-VSS
P0152- 02 sensor
P1762
