I had a shop I use sometimes do an AGR brake swap out on my 2009 dually. I added AGR rotors all the way around, Motul fluid, and the blue printed front calipers. I had them drain all the brake fluid out including the ABS which was a little extra.
Now I have my truck back and the peddle is seriously mushy. I went back and had them bleed it again but it made no difference. I went home and after parking the truck I pumped the peddle to discharge the hydro boost to see what it would do to the peddle. It firmed the peddle right up which tells me the extra pressure compressed the air that must be hiding some where.
Is there some special bleeding procedure that needs to be done to purge air from the truck that isn't the norm on other vehicles? I'm going to take my truck to my normal Diesel truck mechanic at Andre's in Bastrop in the morning but wanted to hear from anyone who may be savvy on this topic.
