yes that would work pretty good, youll have a lot of fuel and that should support it, now for this 64/68/14: the first number is the compressor wheel diameter in mm, the second number is the turbine or exhaust wheel in mm and the 3rd number can be seen two ways but its the size of the exhausting housing, as for 14 it stands for 14 cm2, the other way it can be seen is in a/r, its a ratio of the exhaust discharge area vs the distance from the center of turbine wheel to the center of the cross sectional area. Smaller A/R housing has faster spool up. Bigger A/R housing has less back pressure, more flow for the top end.
