1 - 11 of 11 Posts
Anybody familiar with the sulastic shackles for a smoother ride on the 2018 3500 dually?
On call 24/7
Search around here a bit. Another member did just this a few weeks ago and was very disappointed with the results.
Springs and shocks are the problem. Put Carli 2.5” (level) or Thuren 0.5, 1.75, or 2.25” coils in the front. Run a Fox 2.0 shock from either company with their coils. Cheapest mod for the back is a overload leaf flip and block from TGC and Fox 2.0. Better is a Carli mini pack and block to replace the overload leaf. Best is a custom Atlas or Deaver spring pack. Use a long travel air bag with daystar cradle. Or Sumo springs extended bump stops. All these suggestions need a 2.0 Fox at the minimum.
This post is a few months old so if you’ve done something let us know how it worked.
I ran Thuren springs (0.5”) and Fox 2.0 shocks on my 16 3500. Smoothed it out a bit. Running slightly lower pressures in the tires helps a lot too.
My Thuren 1.75" coils and Fox 2.0 made a huge difference in ride. For a dually I would probably go with the .5 coils from Thuren.
Kelderman 2 stage air bag system provides an incredible ride compared to stock springs.
Smoother ride
What tire pressure are you running?
1 - 11 of 11 Posts
