Here recently my truck started smokin more. The only thing thats on my truck currently is a quad boost fooler and a afe stage 3. The smoke is black which i know is just unburnt fuel but i can hammer down on it and see a black smoke trail and before it wouldnt smoke at all. Ive heard that when your turbo starts to go it starts smokin. Thanks in advance
"MR. ESAFO TO YOU!!"
it might just be soot in the pipe as long as it runs ok your gauges will tell you if your having a prob. also being str8 piped myself, i get soot puffs while idleing.
Black smoke is usually a sign of injector wear. When the nozzles wear they don't atomize as well so more unburnt fuel. Do you run any conditioner?
I suppose you could say the turbo is going and the engine is not getting as much air.
No i dont run any conditioner. And thats what i was thinking about the turbo less air
Where is you boost when you are smoking? If you have good boost then I would not suggest it is the turbo...
Have you checked your air cleaner yet?
i have good boost pressure when its smoking as far as the filter the afe hasnt been but a few months id say 3 1/2 at the most
