1 - 14 of 14 Posts
How much black smoke should i expect with a superchip cortex and afe mega cannon?
very little, the superchips don't smoke that much at all and since your going to be doing the intake as well that it going to help air flow and also burn up the excess fuel.
Mine smokes, i know its not a 6.7 but it still smokes..
You should probably look into an EGR block and DPF delete to really use the power to its full potential..
You will see very little smoke. None if you keep the DPF on the truck.
My truck smokes alot, especially when im at the low end of every gear. I guess its because I still have my EGR on??
as well as the stock air box. Bullydog is pumping fuel in but you cant get enough air to burn it all.
i like my s&b! i've had it for about 4k miles and i haven't had any problems with it, and you can actually hear the turbo pretty good.
So the power pup smokes pretty good if you lug it? I want some smoke, but i would like more horses that what the pup puts out. Has anyone tried or heard anything about the BD Power Ultra X tuner.
I have only talked with one person that has the new X Tuner and he likes it.
The Bully Dog PMT puts out the most smoke.
1 - 14 of 14 Posts
