Smoke Switch???
1115 Views 8 Replies 6 Participants Last post by  kenny110482
what is a smoke switch??? where do u get one and is it easy to install???
thanks
1 - 9 of 9 Posts
· TECH SPECIALIST
You make it yourself with a $3 toggle switch and some wire. Takes 5 minutes but you need some type of fueling box or it won't work without putting your truck in limp mode.
What year is your truck and do you have a fueling/performance box on it? Fill out your sig with your truck info.
thanks for the reply... it a 99... i bought this truck completely stock a few weeks ago so i only have exhaust, intake and gauges as of now. so what do i need to get to make this switch work??
you need a performance box of some kind like a comp box or edge ez. i just recently put a smoke switch on my 2000 an i have a edge ez an it works great you tap into the map sensor:thumbsup
this probably isint a very good idea but ive got and ATS intake manifold and some how all the little fittings for the gauges and what not came out....when they were out my tuck rolled coal like a freight train if your lookin for smoke thats one way to get it i guess
i did it last night on my truck. I connected c and d and put in a 1w 10ohm resister in line with the switch works ok. no codes so far. I had no smoke before but its nothing impressive.
1 - 9 of 9 Posts
