i have a qaudzilla boost fooler on my 03 5.9. i wanted to add a smoke switch on the truck and put resistors on the wires and hooked to a toggle switch. my truck isnt making much smoke and when it does it is on the high rpms instead of the low rpms. should i hook the switch before the boost fooler on the stock wires or on the boost fooler wires? or will it not work with a boost fooler. i look at other threads on smoke switches but so far hasnt helped.
mine is tapped into the stock wires, with a 10ohm resistor.. I had hooked up the smoke switch before I got a boost fooler and elbow... added the fooler and elbow and the smoke switch still worked perfectly, so I left it alone.. I can now hit 35 psi and temps are down a little..
did u hook the two right wires together if you are facing the cab, put a resistor in and still puts it in limp mode for some reason, no smoke either.
maybe differnt tuners need different resistor values??
