Smoke Switch Problem
990 Views 4 Replies 3 Participants Last post by  Mopar1973Man
I just installed a smoke switch on my truck and it workd fine for about 5 mins with no problems. When I shut it off and started it back up the switch quit workin and i threw two codes. a p1693(combination code) and a p0236(MAP sensor code). I took it to autozone and erased both codes and tried the switch again and nothing. I have a quadzillia xillarator 120hp box on it and now that doesnt do anything, it works but doesnt add power. does anyone know what could be wrong? is my MAP sensor screwed? Thanks
:doh:
Best off yanking the smoke switch out and build for power... The smoke switch causes the VP44 to go into full retard timing. Performance wise it kills the horsepower. Trust after playing with it for a few month I did the same thing yanked it out because it doesn't do the truck any good to flood the cylinders with a bunch of fuel it can't burn. Tell you the truth with the price of fuel being what it is your willing to waste fuel for show...
As for the P0236 code its "Boost too high too long"... In other words the ECM see the MAP sensor is high too long. If you going to operate the smoke switch you only want it on for no longer than a few seconds (just like typical boost) other than that the ECM toss the P0236 code.
Thanks for the help. another thing i have now but i unhooked everything is that now its throuwing a p1286(accel pos sens supply voltage too high) p0123(throttle position sens circut high imput) and p0237(turbo boost sensor A circut low). is this something that i can erase with an OBDII er is it something that i have to fix something to make the codes go away
:doh:
Mike, good to see ya postin here again man...i've said this many times but i love your site, and the new look is a lot easier to navigate
try searching "APPS reset" on the forum and do that then immediately clear the codes w/ the scanner...the boost code shouldn't show back up again if you pulled the smoke switch off, but if that apps code shows back up yours could be on the way out
As with the high volt codes double check your driver side ground. As for the low volt on the map sensor I think it could of been unplugged or loose...
