1 - 3 of 3 Posts
i have a 2000 dodge 5spd with a quad xzilerator, i tried hooking up a smoke switch to my quad xzelerator and it didnt work i hooked the wires to the light blue and black and white wires coming from my map sensor on the quad what did i do wrong thanks.. and if i could possibly call u it would b much help thanks my number is 979-220-7651
thats what i did and mine works... seems like after a while it lopes at idle though..
It's got 12 Valves...
I would say you just need to check and make sure you have a good tap on your wires. I did this with mine and found that I did not have a good tap at first. So I would check and make sure you have a good 3 way tap on your wires and they are connected good to your toggle...that is really about all you can do :thumbsup
Oh yeah and I would not run it all of the time...just to be safe..I only used mine for the occasional smoke show :peelout
1 - 3 of 3 Posts
